Error during startup on XC44
Jesus 2 months ago in Expansion modules / XC4x updated 4 weeks ago 2
Good afternoon,
I have a system that uses an MD4-5 as the master and several XCx modules as extension módules. One of the XC44 modules randomly fails to connect when I power up the system, and the LEDs indicate the following error:
"R4:3 3:1:7 Startup check. Expected after update of XC4x to FS capable version."
This error is random; it may not appear for a week or it may appear several times on the same day.
I have checked the wiring and it is correct, as is the battery voltage.
Checking the power supply is a good start.
(all blink codes in the range R4:3 3:1:n relate to a component used for power supply)
What sofware version is the system running?
There is a similar error report here
It is currently running version: 7.05.27.1.0987.
Previously, the machine ran version 7.03.25, but the same error appeared with that version.
