MD5 & MC4x Obsolete Connector
ksilovich 10 months ago in IQANdesign • updated 10 months ago • 2
MD5
34576-0703 (Obsolete) - https://www.molex.com/en-us/products/part-detail/345760703
34576-1903 (Not Recommended For New Design = Going to be Obsoleted) - https://www.molex.com/en-us/products/part-detail/345761903
Code H version is also Obsolete. (34576-0803 & 34576-2003)
MC4x
34822-0013 (Not Recommended For New Design = Going to be Obsoleted) - https://www.molex.com/en-us/products/part-detail/348220013
34566-0103 (Obsolete) - https://www.molex.com/en-us/products/part-detail/345660103
Have you guys seen that the connectors that are used on the MD5's & MC4x are Obsolete, or going to become Obsolete soon.    What is the long term plan for these connectors, as these were just released?  Have you talked with Molex to support these longer?
Just trying to plan ahead, as we mfg harnesses to support these parts. And need to know if I need to buy and stock a lot of these so we don't run into supply issues.
There is a post about this listed under the hardware category:
https://forum.iqan.se/communities/5/topics/4318-molex-connector-part-numbers
Molex have changed the way the dress cover clips in - so all the part numbers have changed.
The transition to new part numbers means the usual suppliers are low on stock so there will be some pain until mid 2026 I suspect.
Thank you, I did not see that post.
