How can I transfer the license key for iQANRun7? How to remove the license from my device?
ykyaw 9 months ago in IQANrun • updated by Gustav Widén (System support) 8 months ago • 1
Could you please clarify how the IQANRun 7 license works?
  • Is multiple installation allowed under a single license?
  • In what situations can a license conflict occur?
  • How to transfer the license key between devices?
  • Ho to deactivate the license? i don't see license manager.
If the same person has more than one device, for example a stationary and a laptop, it is ok to have the same license on both devices.
The same license can be installed for all users on a shared device, for example when the same laptop is used by multiple technicians in an end-of-line test in production.
When transferring to a new device, you can see your full IQANrun license either via Webshop licence recovery / Knowledge base / IQAN, or by running the IQANrun setup program again. (see Lost license number recovery / Knowledge base / IQAN)
To wipe just the license from the old device, you could run the IQANrun setup program again and leave the license blank.
