Looking for way to reset the Integrate(operand) function
Dan Gray 10 years ago in IQANdesign • updated by River 2 years ago • 6
Topic collaborators
I'm trying to use the Integrate(operand) function in a math channel and I would like to be able to reset the function under some circumstances. The only way I can see to do this is to use several lines of qcode. For example:
A:= DerivativeOf(Positon)
B:= Reset
C:= Integrate(Abs(A)) //use absolute value to get total distance traveled
if C = 0 then
D1:=0 //D1 is the starting point
endif
D2:= C //D2 is the end point
D:= D2 - D1 //D is the distance traveled between resets
if B = true then
D1:= C
endif
Result:= D
Is there an easier way to reset the Integrate(operand) function? Perhaps the function could have one or two added arguments, for example Integrate(Operand1, Operand2, Operand3) where Operand 1 is the part to be integrated, Operand 2 is the reset channel, and Operand3 is the reset value?
Thanks,
Dan
Thank you for the help.
Satisfaction mark by Dan Gray 10 years ago
Hi Dan,
The Integrate() function can be reset if the channel where you use it is placed in a function group that you disable.
Another approach is to use Qcode to make an alternative integrate function using a static variable. A few more steps, but you would be able to reset it within the channel.
The topic was posted as a private topic, would you mind if I move this to the public forum discussion?
Hi. Thanks for the reply. I haven't used static variables yet, so I'll have to give it a try. Yes, you can move this to a public forum.
could please expand on how to reset integrate via qcode
One method I have used is to set the integrand to the value of the channel multiplied by a negative number.  This will drive the integral to 0 relatively quickly.
Image 1429
For the next person who finds this thread and asks the same question, see below. I'm not a big fan of using the Integrate() function as its a black box with little documentation. I would recommend just having a static variable that is then added to by the value you are wanting to integrate while still being simple to utilize in qCode.
Image 4426
