+3
Gradient % controlled by math channels
When will i be able to use a gradient bar graph with math channel to set my % for each color. when changing our psi set points i would like a math channel to feed each % based on set pressure. this will prevent several colored bars being over laid and being turned on and off at different pressures based on what attachment is connected.
Gustav Widén (System support) 7 years ago
Gustav Widén (System support) 2 years ago
