Resistive Fuel Sending Unit into MC43?
David Holcomb 9 years ago in Master modules / MC4x • updated by Chris Litwin 9 years ago • 1
Quick question on fuel senders.
The kind we have included with our fuel tank is in fact not a current out, but resistive fuel sender. That is, 1 terminal is connected to ground and 1 terminal is the signal wire with varying resistance based on fuel level.
Is there any way that the MC43 can read this?
We set ours up like the circuit below. I believe the Vin will have to be scaled according to R1 value you use.
