+5
IQAN- MC4x real time clock not available for logs
C. Harp 9 years ago in Master modules / MC4x • updated by Eric Metz 8 years ago • 2
I recently discovered that the MC4x family does not have a RTC pin and therefore when you go to pull a log on a file, it simply gives you a "start number" and a base line of 12:00:00AM. This is not sufficient for what most of my customers needs are.
Are there any plans to add in an RTC pin to enable us to have actual time available when logging.
+5
IQAN-MC4x family ready for production
Johan Lidén (Product manager) 10 years ago in Master modules / MC4x • updated by TKM 6 years ago • 2
Image 559
Our latest generation of controllers are finally ready for production. The IQAN-MC4x family is the fastest and most capable controller range we have ever done. It comes in three sizes to support any application size, from the entry level task oriented control up to the high I/O configuration for complete machine control.
First out from the production line and available now for deliveries is the performance optimized version of IQAN-MC43. The IQAN-MC41 and IQAN-MC42 will start shipping next month (December 2016).
Work is ongoing with the Functional Safety versions and units capable for implementation of SIL2/PLd safety functions is planned for production Q3 2017.
Find more detailed info at: http://solutions.parker.com/LP=7632
+4
IQAN-MC4xFS SIL2/PLd controller series released
Gustav Widén (System support) 9 years ago in Master modules / MC4x • updated 9 years ago • 1
On December 15th, we released the IQAN-MC4xFS series, with safety certification by RISE.
Image 1056
The release means that we now have SIL2/PLd versions on all three sized of the MC4x series:
  • IQAN-MC43FS
  • IQAN-MC42FS
  • IQAN-MC41FS
You can read more about the new product in the press release.
In the press release, we make a reference to the EN 13849-1:2015 update. The EN 13849-1 standard lets machine designers create safety functions either based on electronic components certified by the manufacturer (like the MC4xFS), or design safety functions based on the EN 13849-1 architectures.
With the original 2006 release of the EN 13849-1 standard, there was great emphasis on on calculating hardware reliability, but requirements on safety related embedded software was not as clear as in IEC 61508. Now with the new 2015 update there is a clear limit, implementation of PLr=a and PLr=b functions are accepted on standard controllers, for PLr=c and higher, the use of controllers with safety certification is necessary.
To learn more about this topic and how to design complete safety functions in accordance with EN 13849-1, you can sing up for the IQAN focused training on functional safety.
For documentation of the MC4 product series, see the instruction book.
Molex MX series
minh lam 3 months ago in Master modules / MC4x • updated by Thomas Moberg (System support) 3 months ago • 2
I understand that there was a change from Molex regarding the MX series connector for the MC43. 34822-0013 changed to 216741-0001. The issue is, there is no stock in the US distribution. Are there any other connectors we might be able to use as an alternative until US inventory has stock within the distribution channels?
Coil Suppression on MC4x Outputs
Seneca 6 years ago in Master modules / MC4x • updated by Gustav Widén (System support) 6 years ago • 1
Hardware Question:
In the Documentation for the MC4x family of controllers - it says in many places to use diodes for external coil suppression, for example when driving a relay with the Digital Out HS driver from the MC4x.
A relay that I have specific to my application requires (highly recommends) the use of varistor coil suppression, which is less "harsh" on the relay device during transients. The specification requests a clamping voltage of 3x the coil voltage, i.e. 36Vdc for a 12Vdc relay coil.
Are there any adverse affects of using a varistor instead of a diode for coil suppression?
Perhaps this could be also compatible with the hardware design of the MC4x series of controllers?
(Hint: I already have tested this configuration on my system to many thousands of cycles under load with no discernible affect on system operation or relay operation)
MC43FS - Are there any plans to upgrade RAM/Flash on this module ?
Nick Pridham 7 years ago in Master modules / MC4x • updated by Gustav Widén (System support) 7 years ago • 5
This module supports alot of IO and 5 x CAN. Very simple functions to serve all of the IO and CAN easily burn the available resources and I am wondering if there are any upgrade plans ?
MC41 blink 4R – 1Y – 12Y – 3Y – 1Y – 1Y
Regis 1 year ago in Master modules / MC4x • updated by Gustav Widén (System support) 1 year ago • 6
Hi all I hope someone can help me here,
We tried to update an MC41 via Design and it got stuck at the end of the "Rebooting" phase,
The blinking pattern on the module was : 4R – 1Y – 12Y – 3Y – 1Y – 1Y, and we could not reconnect to it.
Since the unit is rush, we shipped a new MC41 to our shop. After testing they realised some parameters weren't ok, so they went ahead and pushed Settings via Run.
Exact same thing happened : stuck with a full green bar on "rebooting" and pattern that our road guy saw (no video) was "4R - 13Y" but it might very well be the same
Is some of you have seen it before and might know how to resuscitate them ?
Thank you,
MC4x-M24 serial production
Gustav Widén (System support) 2 years ago in Master modules / MC4x • updated 2 years ago • 5
The new -M24 versions are now in serial production:
Upgraded Product
New part number
IQAN-MC41-M24
20085211
IQAN-MC42-M24
20085212
IQAN-MC43-M24
20085213
IQAN-MC41FS-M24
20085221
IQAN-MC42FS-M24
20085222
IQAN-MC43FS-M24
20085223
IQAN-XC41-M24
20085231
IQAN-XC42-M24
20085232
IQAN-XC43-M24
20085233
See updated catalogs:
IQAN-MC4x_brochure_HY33-8413-UK.pdf
IQAN-XC4x_brochure_MSG17-8417-UK.pdf
Requires IQANdesign version 7.03, see Version 7.03 released / Software / IQAN
Answer
Good question!
The -M24 versions will be the ones that will remain.
The classic versions will, due to age of some components, be discontinued within a couple of years.
is it easy to convert from mc42fs to ms43fs
chuck streb 3 years ago in Master modules / MC4x • updated 3 years ago • 4
i need more output io
but it looks like a big tear up
Watchdog Fault on MC41 when almost exceeding DOUT-HS Current (4A)
Kai Rasporich 3 years ago in Master modules / MC4x • updated by Gustav Widén (System support) 3 years ago • 2
I'm hoping someone might be able to chime in if they have seen something similar before.
I'm driving two contactors (they close at different times) off the MC41. The contactors at peak draw 3.9A for about 75ms. When the contactors close, a very short time later, the MC41 enters a critical fault. The flashing lights (4R, 1Y, 12Y, 3Y, 1Y, 2Y) seems to indicate there is a 'watchdog' fault. Looking at my CPU/RAM usage and cycle usage, we are not even using 1% capacity. Is it possible this overcurrent condition could trigger this particular fault?
As well, I can't seem to find any information on what the 12Y is supposed to mean? "R4:1 n:3:1:2" which would be the "n" in the manual. What would the 12th part of the software mean?
