Safe mode! Application not loaded
Theleo De Bruyn 9 years ago in Master modules / MD4 • updated 5 years ago • 6
Hi there!
I've got a small problem and i had this before but it went away every time but i dont know how to fix my problem
if i start up my MD4-5 it shows our own startup screen (this is good) and then, after the startup, it shows an error message:
Image 1172
and it stays in this screen.
I've connected the Bat+ to 24V bat- to the ground and the RTC to the 24V with a 1.5K resistor.
is there any reason why this could happen?
Theleo De Bruyn
Answer
Answer
Hello, Please check if you have connected the Adress tag?
If you start-up IQAN MD4 display's without Adress tag , it will start up in safe mode
Answer
As Jos writes, an IdTag is necessary on the MD4.
Address Tag? how do I check that?
Got it, figured it out, small tag on back with two leads, looks almost like a small inline fuse.
I need information on where I can get one. Rats got into dash cluster and ripped apart wiring to make nest.
please advise
Hello, Connect one of these ID-tags to the Adress-High and Adress-Low (on MD4 Pin C1:6 and C1:7). The ID-tag has to be the same as the one selected in the program.
