+6
​Add photo sensor on MD4 for brightness auto adjust
Pawel Pekala 8 years ago in Master modules / MD4 • updated by Ulrik Zakariasson (Software development) 8 years ago • 0
+4
MD4 temperature
AxelC 11 years ago in Master modules / MD4 • updated by Gustav Widén (System support) 8 years ago • 3
We are in Thailand where average temperature is 35 degree Celsius.
We have 2 MD4 on 2 project, they are hot when running, internal sensor tell 52 degree Celsius minimum most of the time. It is really hot on the finger, our customers are a little worried.
We also have MD3, they are also at more than 50 degree but we don' t feel it on the buttons.
Does all the MD3/4 get hot like this? Is there recomendation to reduce that?
+3
MD4 NVM Write Cycle Limits
nkopec 2 years ago in Master modules / MD4 • updated by Gustav Widén (System support) 2 years ago • 1
Good Afternoon,
I have an application where I am using a Memorizing Channel (MEM) in an adjust group as a user input on a MD4 display. This is to allow a user to enter in a new value with the keypad in the adjust group. For my application, this input will be adjusted very often.
I would like to know more about the NVM write cycle limit of the MD4 displays to ensure I do not wear out the NVM. What is the write cycle limit of the NVM memory on the MD4 displays? Does the Memorizing Channel (MEM) write to memory every time it is updated or does it only write to memory at shutdown of the MD4?
Thanks!
+3
Replacement panel mounting clips for MD4
Justin Wagner 5 years ago in Master modules / MD4 • updated by Marcel 5 years ago • 1
Does anyone know if it's possible to get replacement clips for panel mounting of MD4 modules?
Every once in a while they get lost in the assembly process and I've been unable to find a source to order replacements.
Image 2720
+3
Digital out channel (DOUT) high frequency buzzer noise?
J Kelly 7 years ago in Master modules / MD4 • updated by Gustav Widén (System support) 5 years ago • 8
I have connected a buzzer to my MD4-7 inch display using the DOUT channel.
The signal receives high frequency noise when it is not triggered. Could this be related to the diagnostics tests for internal faults?  - If so how can it be switched off via IQAN design.
+3
IQAN-MD4 mounting bracket for RAM and Southco mounts
Johan Lidén (Product manager) 11 years ago in Master modules / MD4 • updated by JR Repair 12 months ago • 8
Two variants of mounting bracket kits are now available to order
Image 193
(Example picture above is with RAM mount parts, RAM mount parts not included in delivery)
20077778 fits to IQAN-MD4-7
20077779 fits to IQAN-MD4-5
The kits include black countersunk screws for mounting the bracket to the display.
Hole pattern supports mounting of RAM or Southco tilt swivel mount.
Manufactured in black ED-coated steel.
MD4 day/night mode.
Pawel Pekala 5 years ago in Master modules / MD4 • updated 5 years ago • 0
Would be nice for MD4 displays to have day/night mode where background and text properties would change without the need of creating extra layers.
Speaker
Metalfor 11 years ago in Master modules / MD4 • updated by Amine 4 years ago • 1
Hello. I've found in MD4 displays that the only way to handle sound is with one low side digital output for buzzers. The displays have very good screen definitions, excellent images design tools but need internal speaker to give to end users an auditory experience according to the others senses involved when use Parker's displays. I suppose that the only negative point is the IP degree of display will decrease. Bet regards. Diego.
MD4-5 Display page navigation
Greg R 9 months ago in Master modules / MD4 • updated by Jesus 9 months ago • 3
We are trying out an MD5 MD4-5 module for the first time and we have found an issue with display page navigation. this issue does not occur with the same code on and MD4-7. We had buttons on each page that directly linked to other pages but they seemed to not function consistently. The button would register the touch (button lights up) but the page would not change. this was very inconsistent. To try a solution, we made the buttons connect to virtual inputs and linked them to the "show page" parameter and everything worked fine. Have you seen this issue?
MD4-10 white screen
Pawel Pekala 5 years ago in Master modules / MD4 • updated by Gustav Widén (System support) 4 years ago • 3
What might be causing MD4-10 screen to go white.
