Using two(2) or more low side outputs in parallel on XC-23
Guillaume Fournier 8 years ago in Expansion modules / XC2x • updated by Gustav Widén (System support) 8 years ago • 1
I'm wandering if I could use two(2) or more low side outputs in parallel on the XC-23 to increase the carrying current capacity from 300mA to 600mA (2 outputs) or more.  I have a relay that I need to drive that needs more than 300mA.
Thanks,
Guillaume
Thanks Gustav !
Satisfaction mark by Guillaume Fournier 8 years ago
Yes, it is possible to parallel connect the XC23 low-side outputs. Note that you must not exceed the combined load for the group, see Appendix A in the XC23 user manual :
