Low side outputs protection diode
Guillaume Fournier 8 years ago in Expansion modules / XC2x • updated by Gustav Widén (System support) 8 years ago • 1
I need to drive relays on low side outputs on the XC-23 and MD4-5.  Do I need to use relays with included coil protection diodes or if the outputs of these modules are already internally protected ?
Thanks,
Guillaume
Satisfaction mark by Guillaume Fournier 8 years ago
The low-side switches do have protection that will cut the switching transient, but this is not designed for repetitive operation.
You should use a diode at the coil to avoid the transient.
