Replacement For Legacy IQAN-LM Lever Unit
Tim Reen 8 years ago in Levers / LC6 • updated by Julio Caraballo 3 years ago • 5
We have noted that the recommended replacement for the IQAN-LM-3D mini lever is the IQAN-LC6-X05 analog joystick, which has the same small size and 3rd axis option - combined with an IQAN-XC21 CAN module for the CAN feature.
Is it possible to directly interchange the IQAN-LM-3D with the combination IQAN-LC6-X05 / IQAN-XC21 on an older machine with an IQAN Develop platform (MDM system) in the same way the IQAN-LC5-C02 can replace an IQAN-LL unit?
Publ.no: HY33-8405-IS/UK is a good reference for changing out LL units, do you have a similar document for the LM?
It is neat that you can change to the latest generation of large lever unit without any application change, my question is can we do the same for the LM?
Thank you.
Satisfaction mark by Tim Reen 8 years ago
We don't have the same type of drop-in solution that exists with IQAN-LC5-C02 and adapter cable for replacing IQAN-LL.
For replacing an IQAN-LM in a system using IQAN-MD3, the best solution is to update the IQANdesign application and add an IQAN-XC21 as input module for each LC6 lever.
For replacing an IQAN-LM in an old IQANdevelop MDM system, what we do have a partial solution. This consists of an IQANdesign application that can be adapted for use with e.g. IQAN-MC41 together with XC21 and LC6. In this solution, the IQAN-MC41 acts as a protocol gateway implementing the legacy protocol. We are not publishing the project file here,  but OEM:s and distributors looking at creating aftermarket replacement solutions can acquire it via the IQAN support at the local Parker sales company.
Hi!
We contacted the local Parker sales company and they contacted their Parker manager. They said that they didn' t know that this solution even exists and after looking, couldn' t find it :)
Maybe you can tell a reference number or something that perhaps could help find this application in database?
Hi!
SGI Group, in partnership with the Parker-Hannifin engineering team, has developed a solution for replacing Parker IQAN-LM joysticks worldwide.
This solution comes in a Plug&Play replacement kit. In mere minutes, your new joystick will be operating with 100% of the electronic features of the old one. Just simply place the components and connect them with the characteristic green connectors.
The solution comes in two versions so that you can choose the kit that best suits your needs.
https://www.sgingenieria.es/en/parker-iqan-lm-kit-solution/
SGI Group, en colaboración con el equipo de ingeniería de Parker Hannifin, ha desarrollado la solución de reemplazo para joysticks de la familia Parker IQAN LM . Es un kit de sustitución Plug&Play. En pocos minutos su nuevo joystick operará con el 100% de la funcionalidad electrónica del anterior. Simplemente precisa la ubicación de los componentes y el conexionado de sus característicos conectores verdes.
Esta solución se presenta en doble versión,  pudiendo adquirir el kit que mejor se adapte a sus necesidades.
KIT_PLUG&PLAY_REPL_JOYSTICK_PARKER_IQAN_LM.pdf
Image 3919
Image 3918
Thank you for the response Gustav, we have the application you speak of now - through our Parker sales company and we are implementing it. Very pleased there is something we can provide to replace the moving parts in an older system. Thanks again!
Hello Tim,
Hydraulkompaniet have put together a plug-n-play solution complete with wiring harness and software.
Link to our webshop.
https://www.hkhydraulic.com/styrsystem-elektronik/spakar-vippor-knappar/minispakar/lm3dkomverteringlc6
Installation guide:
