MD3 Error Message
mdonaldson 6 years ago in Master modules / MD3 • updated by Gustav Widén (System support) 6 years ago • 1
We have a customer with a MD3 that sometimes works fine and other times just displays this error message. Its running a IQAN Version 2 program.
+AT+IPR?$dAT+IPR?$D
We will replace the display, just curious what is going on.
Thanks
Image 2264
Satisfaction mark by mdonaldson 6 years ago
The MD3 is running version 2.x, and the keypad is damaged. It has to be replaced (or sent for repair).
What you see on the display is a troubleshooting menu for old RS232 dial up modems, it was possible to enter this on startup with a special key press combination.
