MD4-10 white screen
Pawel Pekala 5 years ago in Master modules / MD4 • updated by Gustav Widén (System support) 4 years ago • 3
What might be causing MD4-10 screen to go white.
Moved topic to the hardware section, it sounds as if this could be hardware damage.
If it is not too old I'd recommend contacting the distributor.
Has this been resolved? I have a customer with the same issue, they replaced an MD4-10 and tested the control panel in the shop and it all worked fine. they installed the control panel on the machine and the New MD4-10 screen went white. Could a short of some kind cause this?
My recommendation would be to check the module that was replaced,on a test bench, to determine if it works in a different installation.
If the problem is machine specific, the issue could possibly be with the power supply in the machine.
