XC43 Flashing normal (yellow) with CAN-BUS no contact error on master module and in IQANdesign.
Jamy 5 years ago in Expansion modules / XC4x • updated by Gustav Widén (System support) 1 year ago • 3
I've got two XC43's on a machine. One on CAN-BUS-A & the other on CAN-BUS-B. Both modules are flashing yellow normal operation but the master module says A-BUS no contact & B-Bus no contact. When I run the program in IQANdesign connected to the machine, I also see no contact on both modules.
Why are the two XC43 modules flashing the normal operation flash code and not the CAN error/no contact error flash code?
Planned
Next firmware update for the XC4x (version 1.04) will give a 3:1 blink for this situation.
Came across this again today on a system running 6.08, so wondering in which IQAN version is it fixed?
It was fixed in XC4x version 2.00, released in IQANdesign 7.00
