Difference between XC21, XC22 and XC23
Kevin 12 years ago in Expansion modules / XC2x • updated 12 years ago • 3
What are the differences between these modules? There doesn't seem to be any information online or in IQAN Design user manual.
Thanks.
Information available on http://www.parker.com/ecd now. Click Find Products > Controllers.
Here's a short summary:
The XC21 is an expansion module with up to 20 inputs (DIN/VIN) and 8 Low side DOUT (low current 300mA). It is designed for in-cab or protected exterior use (IP32).
The XC22 and XC23 are variants of the XC21 designed for outdoor use (IP66). XC22 has no voltage inputs, whereas XC23 has the same I/O setup as the XC21.
http://www.parker.com/literature/Electronic%20Controls%20Division/Literature%20files/IQAN-XC21_datasheet_HY33-8410-UK.pdf
http://www.parker.com/literature/Electronic%20Controls%20Division/Literature%20files/IQAN-XC22_23_datasheet_HY33-8412-UK.pdf
Are the XC22 and 23 units available now or still in prototype stage?
