Digital out low side outputs
Nicolas Francoeur 4 years ago in Master modules / MC4x • updated by Gustav Widén (System support) 4 years ago • 1
Is this MC43 output configuration is correct?
Can we power a load at higher voltage than the MC43 power for output 30 to output 46?
Image 3629
very thanks for the answer.
Satisfaction mark by Nicolas Francoeur 4 years ago
Yes, the MC43/XC43/XC44 Digital out LS outputs can be connected as shown.
The module +BAT supply does not matter for connection to these low-current low side switches.
The important parameter is voltage in relation to module ground.
