MD5 Power capability
Neil Skoog 2 years ago
in Master modules / MD5
updated by Gustav Widén (System support) 2 years ago •
5
• 1 duplicate
How current can I draw out pins 56 (bat+) and 29 (bat-) if I am using pins 42(bat+) and 43 (bat-) for the input power. I need to power 2 each IQAN sv120 cameras.
Duplicates
1
On MD5 Display's the +Bat and -Bat have double pin, as double pins for the CAN -A, -B, -C which makes is possible to route the CAN busses
The +Bat connection needs to be fused with max 20 A, however the maximum power consumption of MD5 display units will be below 1 A. You may use the extra +Bat and -Bat pins for secundairy power supply (use external diodes) or to power auxiliary devises, but keep current draw limited within latest MD5 Instruction book specifications!
https://www.parker.com/content/dam/Parker-com/Literature/Electronic-Motion-Controls/Literature-Files/iqan-md5/IQAN-MD5_datasheet_MSG33-8419-UK.pdf
The limiting factor is the current rating on the Molex MX64 terminals.
It depends on the grip size you specify but it is around 10 A.
The traces for +BAT and -BAT inside the MD5 are rated higher, more than 20 A.
The MD5 itself will draw about 0.5 - 1 A (depending on supply voltage)
Each SV will draw about 0.1 A
(merged duplicate posts)
Thank you for your response. I anticipate the camera power will be less than 250 ma.
