Max current on XC43 -VREF pins
Kevin 1 year ago in Expansion modules / XC4x • updated by Gustav Widén (System support) 1 year ago • 1
We are providing some sensors with a 0V supply through the VREF circuit on XC43 module but cannot find the maximum current capacity of these pins. The manual states VREF has a limit of 150mA, but is this limitation on both the +ve side and -ve side?
I was under the impression -VREF is connected internally to the -BATT terminals, therefore does this mean there is a higher current limit? I cant find a value in the manual:
Image 4926
The 150 mA is what the XC4 +VREF can source.
As you guessed, the -VREF can withstand much higher current, up to 10A continuous.
(some more discussion on what this means here Fault Capacity of -VREF / Hardware / IQAN )
But avoid running such high currents in the wires going to -VREF, as that could elevate your sensor ground.
