Driving Pulsar with the PWM on MC43
Corey Bobbermien 1 year ago in Master modules / MC4x • updated by Gustav Widén (System support) 1 year ago • 3
Hi There,
Hope all is well,
Is there any possibility to drive Proportional 24v 33Hz Pulsar valves with the PWM outputs from a MC43 ? Reading the manual it states that this will not work from MC43,but reaching out to see if it is possible.
ATM I am using the proportional flow from the pump and making the Pulsar more like an ON/OFF, This is working currently but would like to use the Pulsar proportionally.
Thank you
The lowest possible frequency for PWM out on the MC43 is 71 Hz.
Parker do have a 75Hz Pulsar valve option.
Thanks Tim,
I Will try with a 75Hz Pulsar,
I was just Hesistent because the MC manual Had Mentioned this reference.
NOTICE
PWM out HS+LS has an internal free wheeling diode.
Because of the internal diode, this output is not suitable for Pulsar® 33 Hz or 75 Hz
digital poppet style pilot operated valves.
Hi Corey,
You are right, I hadn't notice that before, but the instruction book clearly states the PWM out HS+LS and even the PWM (HS) are not suitable for for Pulsar® 33 Hz or 75 Hz digital poppet style pilot operated valves due to the requirement for external diodes. Apologies for any confusion caused.
