MD4-5 Display page navigation
Greg R 9 months ago in Master modules / MD4 • updated by Jesus 9 months ago • 3
We are trying out an MD5 MD4-5 module for the first time and we have found an issue with display page navigation. this issue does not occur with the same code on and MD4-7. We had buttons on each page that directly linked to other pages but they seemed to not function consistently. The button would register the touch (button lights up) but the page would not change. this was very inconsistent. To try a solution, we made the buttons connect to virtual inputs and linked them to the "show page" parameter and everything worked fine. Have you seen this issue?
Correction. Its not an MD5 its an MD4-5. We have tried on 2 different modules with the same issue. no problem in sim. It works fine on the MD4-7
Thank you, I edited title and original topic to show the problem is on an MD4-5.
The issue may be with the touch precision of the MD4-5-M19, it is not as good as the MD4-7 or any of the new MD5 displays.
For menu navigation, version 6.08 introduced an improvement by increasing the touch size zone for symbol buttons (see Release notes - IQANdesign 6) , but this is more of a workaround.
I have the same problem. Especially when navigating the menu, sometimes the menu scrolls all the way to the end when you tap the screen.
This problem mainly occurs during the first few minutes of use in the morning, when the display temperature is low. As it warms up, it works better.
