MD5-10 Display Blink
Tim Reen 6 months ago in Master modules / MD5 • updated 6 months ago • 2
We have an MD5-10 display that transitions from the current display page to a black screen and then returns to the display page again. Seems to be about 2-3 seconds showing the display page and then about 0.5 seconds black. The issue does not appear to be program related because it has the problem even when you are in menu mode. We have noticed that turning the brightness down < 80% seems to make the issue go away.
Part number: 20085203
Serial number: 2444230031
Is there any known problem here?
Is this on the bench? In that case, what is the current capacity and supply voltage of the power supply?
What SW version is the MD5 running?
The MD5-10 is in a working system, mounted on a truck with a 24v electrical system.
The SW version is 7.05.27
Image 5333
