XC43 Magnetoresistive Transmission Speed Sensor Integration
Daniel Small 4 months ago in Expansion modules / XC4x • 0
Our transmission manufacturer uses a 2-pin magnetoresistive (MR) speed sensor.  The output is 7 mA for low signal and 14 mA for high signal.
The frequency range would be 0-1500 Hz.
Given that FIN is looking for <1V low and >4V high on an XC43, we can't condition the signal with a simple current-sense resistor.
Do you have any suggestions on how to integrate this type of sensor into a XC43 module?
