MD5 DOUTHS 5V Application
Rodolfo Barce 6 days ago in Master modules / MD5 • updated by Jamy 6 days ago • 1
In the IQAN MD5 Instruction Book, for digital in (DIN) it gives an example of powering the switch using the DOUT HS 5V. in order to ensure there is constant 5V supply to the switch, you simply use an IDC with “True” as activating to power it?
Related to that, could we use that 5V DOUT to power a buzzer (5V, 2mA) and use the DOUTLS to control it? The example is not explicitly shown in the instruction book but, logically, seems like it should still work.
Yes, you can use an IDC with “True” as its activating condition to activate the MD5’s DOUT HS 5V. You can also set the DOUT’s activating condition directly to “True,” so a separate IDC is optional. This keeps the 5 V output enabled while the application is running. Your proposed buzzer arrangement should also work. Connect the buzzer’s positive terminal to DOUT HS 5V and its negative terminal to a DOUT LS. Keep the 5 V output enabled, then activate the LS output when you want the buzzer to sound.
The 5 V output supports up to 150 mA, and each LS output supports up to 300 mA.
