6.08 Application Load Error
Jon Coopland 4 years ago in IQANdesign • updated by Gustav Widén (System support) 4 years ago • 1
I'm currently working on a dual master system using IQAN Design 6.08.24. When loading an application with 24V DIN on C2:1 or C2:2 it stalls at the finalizing and doesn't go through the restart, And when cycling the power it gives an error for an incorrect address tag. I tried loading the same program on another machine and had the same results, Unless the C2 was unplug or if I used 6.07.
From the description, the symptoms sound as if you have version 6.08.22 in your MD4
There is an earlier discussion here Address tag not recognized 6.08 / Software / IQAN
Are you sure the module got 6.08.24?? That problem should no longer exist in 6.08.24.
Latest IQANdesign is 6.08.28, see Release notes - IQANdesign 6.
One reason you haven't used the latest may be the issue we had with Check for updates, Check failed / Knowledge base / IQAN
