IP Cameras HTTP Streaming Phone Screen
ksilovich 4 years ago in Master modules / MD4 • updated by Lars Bolduc 4 years ago • 3
I have a project where I am trying to stream a video of my cell phone to the MD4 display.   As I want to be able to view google maps on the display for an in cab display.
I noticed in this post that it looks like the MD4s support HTTP streaming,
https://forum.iqan.se/communities/5/topics/295-md4-updated-list-of-tested-functional-ip-cameras
And I found this app that will do HTTP streaming via MJPEG
https://github.com/dkrivoruchko/ScreenStream
And then I get an access point connected from my Phone, PC, and MD4 display.
The phone has an ip address of 192.168.128.10:8080, and I can view the stream on the PC, but I cannot view it on the display.
I tried to type in "HTTP//192.168.128.10:8080" in the URL and that didn't work, and then I tried just the port of ":8080" in the URL.
Can you confirm that the MD4s support HTTP streaming and if so what port are you using, as I can change that in the app settings if its not 8080.  And how would I configure this in IQAN
The MD4 did support MJPEG over HTTP, in version 3.
This was changed with the release of version 4 in 2015/2016, when the SV camera and generic camera module was added.
The generic camera module in IQANdesign support MJPEG over RTSP/RTP
Well that sucks, because I can not find any app that supports RTSP/RTP screen share streaming.     Is there a reason HTTP was removed, could it be easily be re added to the support so we could do this?
As a note I was unable to get RTP (Raw stream of UDP packets) to work. Only RTSP (video stream addressable as a URL) worked.
