MC4x-M24 serial production
Gustav Widén (System support) 2 years ago in Master modules / MC4x • updated 2 years ago • 5
The new -M24 versions are now in serial production:
Upgraded Product
New part number
IQAN-MC41-M24
20085211
IQAN-MC42-M24
20085212
IQAN-MC43-M24
20085213
IQAN-MC41FS-M24
20085221
IQAN-MC42FS-M24
20085222
IQAN-MC43FS-M24
20085223
IQAN-XC41-M24
20085231
IQAN-XC42-M24
20085232
IQAN-XC43-M24
20085233
See updated catalogs:
IQAN-MC4x_brochure_HY33-8413-UK.pdf
IQAN-XC4x_brochure_MSG17-8417-UK.pdf
Requires IQANdesign version 7.03, see Version 7.03 released / Software / IQAN
Answer
Answer
Good question!
The -M24 versions will be the ones that will remain.
The classic versions will, due to age of some components, be discontinued within a couple of years.
Please explain what -M24 is all about.  I do not see information on it anywhere.
Thank you
-M24 is a hardware maintenance update for MC4x, MC4xFS and XC4x.
Some of the components such as the lowside drivers and CAN transceivers have been upgraded to newer versions, to make sure we can keep building it without interruption.
In IQANdesign you use it like the original, when the IQAN application is updated to 7.03 or newer it runs on both versions of the hardware.
A nice improvement is that the new CAN trancievers have SiC, improving the ability to run higher CAN FD speeds in practice.
Thank you
Will the -M24 modules remain something you only order if you want them, or is the entire line going to migrate to being all -M24 modules?
Answer
Good question!
