+58
Native CANopen support
Peter Bo 12 years ago in IQANdesign • updated by Andrew Slaght 3 months ago • 16
Add dedicated CANopen channels to simplify implementation of CANopen communication. Also, support for EDS files would be nice.
+45
String functions
Gustav Widén (System support) 9 years ago in IQANdesign • updated by Jesus 10 months ago • 8
There are a few different forum questions and feature requests that I think would be possible to solve if we had added some string handling functions, for example comparison of text channel values:
http://forum.iqan.se/topics/1006-any-way-to-store-serial-number/
http://forum.iqan.se/topics/403-convert-machine-id-to-numbers/
,string concatenation:
http://forum.iqan.se/topics/162-idea-ability-to-change-tp-channel-value-using-qcode/
and conversion from integer to text
http://forum.iqan.se/topics/863-ascii-characters-from-j1939-parameter/
Anyone else who thinks this could be a good idea?
+32
Ethernet/modbus communications protocols on MD4?
David Holcomb 12 years ago in IQANdesign • updated by I CAN GO 2 years ago • 6
We frequently are integrating IQAN into larger systems that frequently have Ethernet/modbus in use.  Any hope of getting communication over the ethernet ports?
+27
touch number pad for adjusting parameters with MD4
andyr 12 years ago in IQANdesign • updated by Gustav Widén (System support) 1 year ago • 26
using MD4 to adjust function parameters within adjust menu, could a pop-up touch number pad be made available as an option to enter a new value rather than scrolling which can take a long time if the adjust range set is wide with a small increment step number
+26
IQANrun - Bluetooth connectivity
Raimund Pelz 10 years ago in IQANrun • updated by Gustav Widén (System support) 5 years ago • 6 • 1 duplicate
Please add the possibility of Bluetooth connectivtiy to IQAN Run for maintance purpose between Laptop and IQAN controller via G11 Bluetooth adapter.
+23
Free text comments in IQANdesign functionality view
It would be nice to have the possiblity to add a box for entering comments in the functionality view.
The Description field of the channels and objects work, but one must click on the individual channel to see it, or use the Project Documentation generation to see a more complete list of all descriptions.
+20
Sub-Groups in Adjust Groups
Barth Hollanddrain 11 years ago in IQANdesign • updated by Gustav Widén (System support) 4 years ago • 9
Is it any way possible, or be made possible to create subgroups in the adjust-groups?
The applications we create use a lot of costumer-dependent values.
We use the MD4/5 screens on our machines, also to adjust values/parameters in the program.
Calibrating our systems takes a lot of time now, simply because of scrolling and searching for the right parameter.
Having sub-groups would speed things up.
Also having those subgroups optionaly password-protected would be a good addition.
+19
Any plan to support importing EDS file?
Frank GUO 8 years ago in IQANdesign • updated by Gustav Widén (System support) 4 years ago • 4
Is there any plan to add importing EDS file into IQAN?
+18
Zoom tool in IQANdesign
It would be nice to be able to zoom in and out in the function group view and the system layout view.
+18
Lamp feature for lables
Fredrik Forsberg 12 years ago in IQANdesign • updated by Grisel, Evert-Jan 3 years ago • 8
It would be nice to have lables with lamp function. Be able to define "Input channel", "ON color" and "OFF color" for lables.It would be easier than making two lables as we do now.
