XS2 Dout to +bat?
Forrest 3 months ago in Expansion modules / XS2 • updated by Gustav Widén (System support) 3 months ago 4
I'd like to have IQAN control be paralleled with switch control. This specific application will be a drop axle. I want the IQAN to drop the axle in certain situations, and have a switch that will drop it at any time, even if the control system is powered down,
I believe I have to protect the module from back-feeding, correct? Will just diode protection be enough or do I need to have the Dout controlling a relay that would toggle the input between the switch and a +bat source?
